I should say...multiply the startup airflow by 1.76 in the 0 seconds column...then sorta smooth that difference into the rest of the table based on run time...so multiply each column by less and less. Essentially you can use that table to do the same thing your foot is doing when you pedal it...giving it more air to fire up.
