Results 1 to 2 of 2
Thread: OBDII code for oil pressure?
    Tuner midgetracr's Avatar
    May 2006
    NW Indiana
    153
    I have a GMPP crate LS7 engine with an E67 VCM and have dyno'd the engine on an engine dyno. During the dyno testing we used HP Tuners to display engine oil pressure, TPS, coolant temp and several other parameters. Obviously that info is available in the data stream presented on the OBDII port.
    Today I purchased a digital dash and chassis data logging system to be used on my new road race car. After plugging the new dash/chassis logger into the OBDII port I was pleased to be able to display and record TPS, coolant temp, RPM and numerous other parameters. However no oil pressure reading was shown.
    When talking with the logger manufacturer's tech people, they offered to add the oil pressure reading to the info they collect if I could find out for them the location in the OBDII data stream that covered the engine oil pressure signal.
    Will someone post or send me the file format info needed to answer this question.
    Thanks in advance for any help that will be provided.
    Midgetracr
    May 2006
    NW Indiana
    153
    Got my answer. Problem solved.
