Results 1 to 4 of 4
Thread: Please Look over my tune
    Jul 2006
    32
    Just wanted to see what you guys think of it. Its all been done on the street. Used a friends wideband o2 to calibrate the AFR
    2000 LS1 4l60e Mods:
    -Long tube headers
    -LS6 Intake
    -Port and Polished stock TB
    -CAI
    -3" single exhaust with flow master Y
    -3:42 gears
    -Vig 3500 Stall
    -Trans-go Shift kit
    HPtuner scan.hplLs6 intake Tune - S3 TB-long tube-AFR 6-5-11.hpt
    Joey
    Nov 2012
    6
    Any reason you took tons of timing out of your low octane spark table? and "recalibrated" the maf?
    Jun 2013
    21
    I can tell from your narrowbands you're running 14-15 AFR at WOT, way too lean (they're switching at WOT). Fuel trims are jumping around more than I like to see too. Either your maf is dirty/stuffed or fuel pressure is sagging under load, you need to check fuel pressure under load before going any further. Then dial in the maf preferably with a wideband. Pull out some timing and put the knock sensor sensitivities back to stock untill you get the fuel/air sorted, you're running close to stoich at WOT with desensitised knock sensors at the moment which is dangerous.
    Jul 2006
    32
    Thanks guys! I appreciate the input. I will have a dyno available this weekend. Will try and sort stuff out. Thanks again
