I get the delayed start/extended crank and A/C disabled message on my '12 after a flash. Let it sit and no A/C message but it still cranks a while.
OS 12649046
Its a 2bar MAP - Speed Density # 1250235 converted from 12637084
I don't remember exactly how it acted before I converted to the 2bar speed density enhancement... but I do know I never had to wait before starting it after a flash... but I do remember a delayed start occasionally after flashing.
2010 Camaro LS3 (E38 ECU - Spark only). MS3X running complete RTT fuel control (wideband).
Whipple 2.9L, 3.875" Pulley, kit injectors, supplied MSD Boost-A-Pump, stock pump
LG Motorsports 1 7/8" Headers - No Cats, stock mid pipe with JBA Axle Back
ZL1 Wheels/Tires
2010 Camaro SS M6. Stock Bottom End, Heads/Cam/Intake/Headers/Exhaust.
2005 Silverado RCSB. Forged 370 LQ9/Borg-Forced Inductions T6 S484/Jake's Stage 4 4L80E with D3 Brake/4WD.
2023 Durango Hellcat
I also am having this same issue!! I need help!! Need this motor running this weekend! Tuning a motor as stand alone for an airboat. Any help greatly appreciated!
Any luck on this issue? My car is a mid 2010 2ss/RS with back up sensors.
Chris what does a read do that write should do in the end? What ever this resets seems to fix the issue. However, if I do not do a read after a write I have a better chance of hitting the lottery then my car starting.
I haven't heard anything yet.
guys, please try 2.24.270 or later for a fix to this. Please let me know if you still have problems.
Chris...
I count sheep in hex...
Chris, do you think the AC warning messages are normal? I get them immediately after flashing, but she always starts after flashing... sometimes slightly delayed though. Just curious if this AC message should go away. I assumed it only pops up since the CAN bus was reset, and something lost communication.
ZL1 Wheels/Tires
ok I answered my own question... using 2.24.271 I get no more AC Disabled message, and it starts much faster immediately after flashing! Good Job thanks!!!!!!
ZL1 Wheels/Tires
glad to hear it, I've got plenty of guys that have been waiting on this for quite some time now
What was the issue out of curiosity? I only seemed to get it on cars fitted with FPCM, don't know if it was a coincedence or not.
I'll test it when I see a known issue car next time I see it and report back. Thanks for the reply!
Going out to the garage to test it right now...I'll post back in a few minutes I hope.
It's not 100% fixed. It seemed right after the first flash...but I was doing some more VE work and eventually the car started refusing to start again...so I let it sit for 10 minutes and it fired right up again.
