Results 1 to 15 of 15
Thread: IFR's
    IFR's
    Im trying to change my ifr and im stumped the settings now are 3.18 from 0 to 80 kpa subtracting comes to 0 my new inj are 10.97 g/s do I just put that across the 0 to 80
    Aug 2009
    Calibrating
    3,373
    Are you return or returnless? That will dictate how you setup the IFR and offset table.
    15 C7 A8 H/C 2.3 Blower/PI
    14 Gen 5 Viper
    Its return. I,m using a vette filter instead of the original vacume refrence regulator.
    Aug 2009
    Calibrating
    3,373
    return is the same values across.
    14 Gen 5 Viper
    Ok . Thanks for the info.
    Senior Tuner Russ K's Avatar
    Dec 2005
    Regina, Sask.
    4,214
    Quote Originally Posted by Ben Charles View Post
    Only if there is a vacuum/boost referenced regulator.
    Russ Kemp
    Ok. I have a 408 with a TBSS intake and fuel rails and I have the corvette filter with the internal regulator which returns fuel. So should my ifr be linier or graduated. If graduated what would I start at. The injectors work out to 10.97 g/s @ 58psi
    Dec 2005
    Regina, Sask.
    4,214
    87.1 lbs/hr at 0 kpa & 95.4 lbs/hr at 80 kpa. Then interpolate between horizontal bounds.
    Russ Kemp
    Thanks Russ.
    When i interpolate between the horizontal bounds its reducing the values till it gets to 80 where i have it set at 12.0 it drops from 10.9 @ 0 to 3.18 @ 75 why is it not raising to match to the 12.0 I got it figured out.
    Dec 2005
    Regina, Sask.
    4,214
    No idea what your trying to do, post your tune.
    Russ Kemp
    I got the settings figured out. But what confuses me is the vac to pressure its like its backwards . 0 vac should be wide open throttle and 80 closed. why would the pressures not be the other way higher at 0 and go lower to 80. ?
    Senior Tuner Iam Broke's Avatar
    Jul 2009
    2,305
    Absolute pressure, remember atmosphere (0 vacuum) is ~ 1 bar or 100 kPa
    Quote Originally Posted by Iam Broke View Post
    Ok I think I got how it works now. So 0 kpa would be full engine vacume. Thanks for that info.
    Tuner longboxdime's Avatar
    Sep 2011
    birthplace of GM- Flint, MI where the water is heavy
    64
    I apologize for hijacking, but I am trying to make sure I understand. In absolute values (of negative pressures below atmospheric) 0kpa would be 0kpa and 80kpa would actually be -21kpa gauge pressure? I am old and it does get confusing, lol. I wonder why they base it this way instead of gauge pressure. Is the IFR the only table that is constructed this way?
