Results 1 to 3 of 3
Thread: EFR turbo install Multiple issues, boost creep, BCDC not giving desired
    Hey guys, I am working on an LNF tune and having some issues dialing the boost in.
    I have 2 issues. First the car has major boost creep. The car will spool to 12 psi at 4k and by redline it will be 28-30 psi @6500. I have been playing withthe BCDC to try and level it out. Right now boost is pretty good at redline the problem is there is a transition from 500-600 where I have to ramp down the WGDC from 70% to 0 in order to keep the boost from overshooting. Here is where the second problem comes into play. right at 5100-5300 the boost drops from a steady 23-24 to like 19. I believe it is because the transitioning of the WGDC. at 5300 I am commanding 70% of WGDC but it is showing something a lot lower. Can you guys help me figure why this happens. Also the I have maxed out all of the torque tables. The Pedal is at 100% so I do not think it is any tq management causing the issue.
    Thanks for all the help.
    Dec 2008
    Nevada
    4,452
    first a few questions for you mate....
    Where is your tune file?
    What are your dals looking like?
    What gear are you doing your wot pulls in and are the rpm x gear modifiers off in traction control system.
    boost creep is effected by many of environmental factors and corrected for by using a specific array of tables. 5 come to mind to be exact so a tune would help everyone on here point out things that could be affecting multiple areas in your tune. usually if its creeping boost i find a few of the other tables to be interfering as well. It happens in my own tunes as well so dont feel singled out.
    Apr 2013
    Edmonton, Alberta, Canada
    99
    Finnicky little Mofo's I must say lol.. I'm STILL working on getting mine where I want it; but I've modified a couple of tables completely and it's smooth.. need moar powah though lol Hope to soon have it where I think it Should be.
