Hi all my first post and new to tuning GM LSX engines although I have been tuning for many years Japanese Turbo Engines so I know the basics but admit I have a lot to learn
I've just fitted a Magnuson MP1900 to a 2005 LS2. I've made a few changes to the ECM file including the change to 2 Bar OS, modified the Injector Flow Rate vs KPa for the larger 63lb injectors, created the expanded map in the Main VE Boost map, Modified the Power Enrichment EQ Ratio and Enrichment Ramp in. Pretty much setup as per the video guide form the HP Tuners guide Applying 2 BAR SD HERE.
My setup is still running MAF with a 2 Bar MAP sensor, rest of the engine is stock. Car starts, idles and drives fine under light to moderate acceleration, anything substantial and the fuel is cut which I verify from the trip computer instantaneous fuel display.
