Results 1 to 6 of 6
Thread: how to delete traction control function corvette 2000 YSi supercharged
    just would like to cancel traction control system in the tune ...
    may be i m wrong but i ve deleted the p1571 dtc and set it to no error reported..
    anyone help woulb be great... thks
    May 2013
    Houston
    105
    Can't set Retard Vs RPM to zero for all cells?
    Aug 2006
    5BA8
    3,210
    If this is your car, then no problem. If it is a customer's car, I HIGHLY recommend NOT doing this, even if they're asking you to.
    There are zero instances where I would completely eliminate TC. Even in a race car, you can turn it off with a switch.
    EFI specialist
    email=[email protected]
    Dec 2008
    on the Dyno
    1,825
    Same here. I get some previously tuned cars in from time to time with this stuff disabled and I always turn it back on. The button works to turn it off.
    Located in Central Kentucky
    ShorTuning
    the button seem not to work all the time..
    so it is for that reason that i want to turn it off
    Dec 2008
    on the Dyno
    1,825
    Is it your personal car? Post the file?
    ShorTuning
