Please look. I'd like to review your boosted data logs
Ok, so I have a 2002 ZO6 with a Vortech Supercharger. The VCM has a 2bar OS and I've just learned how to log boost (or so I think) utilizing a custom PID. I went into the VCM scanner, opened the primary table, right clicked and selected insert. The insert PID pop up box came up and I double clicked on the configure user defined. I selected a user defined PID that is not being used (undefined) and I named it boost. I then selected the MAP sensor from the "sensor" drop down menu and I selected PSI from the "units" drop down menu. The next thing I did was create a function string. Now based on what I've been reading, the data I need to enter in the function string is [PID.11.IMP]-14.5
After that I closed the box and saved the config file as directed by the pop up box that ask if I wanted to commit changes. Next I went back to the primary table and right clicked went to insert PID's and under user defined I double clicked my new user defined PID.
Even though I'm sure I went through the operations correctly to set this up I do have some questions. First question is when I'm at the part where I need to add the function string, I have more then just PID.11 available. The PID's that I have that I think I can use are PID.2332 Manifold Air Pressure, PID.2333 Manifold Air Pressure - 2 bar, [AUX.20021] 2 BAR MAP - GM and [AUX.20121] Boost. Which one do I use for my application?
Like I said I think I got it right I just want to make sure so if I could see someone's log file (someone who has an OS like mine) so I can verify, that would be great. I'd go test it out on my own car but its not here at the moment. It's having a different cam installed among a few other things.
Thanks Gents!!
I know someone has what I need.
I have a boosted '03 Z06 with a Novi 1500. Here's how my scanner is setup for VE tuning. After a run I just use these 2 filters.
Part throttle tuning I plug this in the VE- AFR Error
[SENS.90] > 15%
WOT tuning I plug this in the VE- AFR Error
[SENS.90] > 80%
Here's my scanner and a run
Thank you Daniel. I was looking for someone who has a log file and is logging boost the way I described above. I need to see if my custom boost PID is working correctly. Id use my own car but its not here at the moment.
