you have to tell the computer that you now have a more efficient blower. you do this by telling the VE table that your engine is more efficient now. when you do that the VE will light a fire under the asses of your fuel injectors.
ok so here's how you do this.
there's 2 ways (for the most part) to control fueling on your 2 bar OS one is the main VE table and the other is power enrichment (which we will get into in a bit)
so what you need to do is create a histogram that logs VE AFR Error percentage. once you do that go and do some driving/data logging. take the car and just drive normal try to stay out of boost for the time being. once you populate as many cells as you can your going to stop scanning and save your log file. go into the log file and into the VE AFR Error histogram and ensure it is set on average count (the A in the top right of the window). Copy the histogram you just recorded, open your tune and go to the main VE table. left click on the empty box on the left of the main VE table (this will highlight the table in all blue) then right click and select multiply by percent. save your tune as a new file (DO NOT SAVE OVER YOUR CURRENT TUNE) save it as something else so that you always have the tune you started with. load tune on vehicle and go out for more data logging. repeat process until your error is 5% or less. this shouldn't take you long for the part throttle stuff in your tune because based on what I can see your error is very close (in fact looking at it now if it was me, id leave it alone) however it can still be tweaked slightly if you must. then do the same as above for WOT. don't worry about your PE table as it is set correctly (hes got you at a very safe 11.1 : 1 across the board when in PE) its the VE that appears to need some work At WOT.
KEEP THIS IN MIND ALL OF THIS IS MY ASSUMPTION THAT YOUR WIDEBAND IS WORKING CORRECTLY AND THE VOLTAGE OFFSET ISNT WACK. Sorry, im not yelling lol
