Results 1 to 3 of 3
Thread: 2005 Silverado SS Speedo Change?
    Jul 2013
    I had a question on changing the speedo for larger tires. I setup for Modify Stock Tune. In the menu I selected adjustable parameters/actual wheel size. Punched in my width, aspect ratio, and wheel size and then save. Saved the tune and exit the ECM. Just to double check I went back to the same menu for wheel size and it is asterisked as it should be but when I go to the data it says "not set" Am I missing something in respect that it is already sent but the tuner just doesn't show it for that session? I would assume it should show my last saved values from my tune. Also the tire height menu shows 36" even though I'm running a 30" tire. Even after I make my adjustments. Thanks for any help
    Senior Tuner Russ K's Avatar
    Dec 2005
    Regina, Sask.
    4,213
    Post your stock & tuned file. No one can help without it.
    Russ Kemp
    Jul 2013
    Never mind I got it. Thanks
