The car is now idling rich. You can smell it out the tail pipe. What could of gone wrong from one day to another to throw the car into a very rich condition at idle?
I have larger problems now. I got a dtc. but now hp tuners cannot find my vcm whether in scanning or editing mode. I tried a different usb cable. the cable is fine.
all very strange. after 5 minutes of driving I tried the scanner in a parking lot. it worked and brought up some U codes.
TCM disconnected from something. At any rate I was able to then use the editor to reflash and the codes are gone and the negative fuel trims are back at around -3. All too weird. While I was having the problems and I would start the car it almost sounded like the starter going out once or twice.
Sorry,, spoke too soon. I guess that was a separate problem which I seem to have fixed. I do not know how I fixed it. But for now that is fixed.
Now I am back to the minus 21.3s. I do smell a little fresh gasoline from the car. Why am I not throwing a code for this? I guess I will have to bring her in to see where the leak is.
You have to be careful calibrating the maf off of fuel trims after flashing the car with an e38 pcm. For whatever reason on various cars I have seen the ltft's act crazy after a flash. I usually do an update then drive the car for a while to let everything settle then reset ltft then calibrate the maf.
Squirrel stuff
Did you reset ltft every time you flash? Try and calibrate always with ltft+stft at the beginning
are you o2 switching?
Remote Tuning [email protected]
2007 Corvette C6 Vert. A6
LME LS402, Pat G custom cam, ATI 10% OD Damper
Circle D triple disc 2600, 3.42 Diff
YSI, 3.0 pulley, ID 1000's
Alky Control Meth,
ARH 1 7/8 headers,
1009 RWHP @ 7000, 817 RWT @ 6000
