I've been at this for a while now.......
6L Auto, RamJet, HSV Headers, J-Pipes....... Have V4 mode enabled..... Wideband Tuned MAF - Street, VE .... Partial Wideband/Guestimates Custom OS 1 Bar Layout.
I have an issue with the LTFT's essentially adding or subtracting too much fuel........ mostly in off throttle, super low rpm V4 mode or low rpm DFCO.....
It seems like it's almost going into DFCO in spots, leaning way out...... I'm lost.... it's so annoying, I just need the lower region fixed up so I can move on.
Dynamic Airflow seems perhaps low, not predicting enough at times.......
Take a look at the log. I can turn V4 mode off 6th gear, under DFCO on TPS Enable... setting 1024rpm or lower to .003 and most of these lean spikes go away on the lower airflow....... but I want to keep those two things for economy...... but I have to fix the weird trim issue with the LTFT's either pumping too much or too little........ essentially wasting fuel and it's bad for the car.
I had throught with DFCO of changing the entry/exit spark for the 1024rpm or lower area to see if that would help but I dont fully understand it yet.
Take a look at the scan.
