Results 1 to 5 of 5
Thread: P0036 code on 07 Grand Prix GXP 5.3L
    Jul 2012
    Indiana
    3
    I have taken out the stock down pipe and installed a 3" down pipe with no cat or rear O2. The car keeps throwing a P0036 code for the rear O2, When I go in to find the code to turn it off there is no P0036 code in HP Tuners to shut off. Thanks for the help.
    Dec 2009
    1,084
    Post file in question
    Mar 2004
    British Columbia
    90
    It's there, look harder, or update your HPTuners Suite if needed
    Advanced Tuner blownbluez06's Avatar
    Jan 2008
    Forney, TX
    982
    are you configured for advanced settings? If not, the software will "dumb" things down to help keep you from getting your ass in a crack.
    Hsquared racing engines RHS 427, Procharger F2, Moran Billet Atomizer injectors, Alky Control,Mast LS7 heads, Nitrous outlet kit,Tilton quad disc clutch, DSS shaft, RKT56 ZR1 trans, RPM Quaife diff. Built and tuned by yours truly.
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,261
    FYI even setting the view to basic will still show the DTC listing just as it would set to advanced.
