anything over half throttle it seems to slow down, fuel pressure stays around 60 psi, this is a stock 2002 5.3 in a 74 c10,
what size is your fuel line? you need 3/8 . how big is the air filter? have you ran a vci scanner to see if the sensor are all woking correctly? the only thing i see that your missing is under systems> prndl you need to change it to none.
2004 avalanche z71 4x4 5.3 turbonetics t62 turbo ,z06 cam 4l80e.
1966 nova stock 5.3 ,t66 turbonetics turbo ,z06 cam,700r4 trans 3.73.
it has -6an line fuel line, cheap cone style filter, thanks
