Results 1 to 8 of 8
Thread: Rich Idle - First Start ID1000s / 411 PCM / 365 cu.in 78mm Turbo
    Jun 2012
    Pirate Ship
    93
    Have a new combo I am trying to get running good enough to tweak and tune. I have all the ID1000 data copied into the turn from the ID website and also did the 2 bar SD OS. Even with the VE table in the 2-3 value range in the 0-1600 rpm range the vehicle still will not lean up to around 14.5 or 14.7. I am running vacuum ref and have 58 psi of rail pressure and 104.xx in all the flow rate vs. kpa tables. Should I think about lowering the fuel pressure or is there a setting I am missing to get it started and idling good
    Senior Tuner DSteck's Avatar
    Mar 2008
    St. Louis, MO
    4,859
    Go to the transient fueling tab and set the min fuel milligrams to about 20% of what it is.
    http://www.dsxtuning.com
    Just say no to bull s***.
    Jun 2007
    Finland, Europe
    549
    That parameter should be included in ID Excel sheet to avoid this kind of problems.
    Mar 2008
    St. Louis, MO
    4,859
    Maybe, but its not a parameter specific to their injectors, so they aren't responsible for showing people a generic required edit.
    Advanced Tuner HartRod's Avatar
    Dec 2006
    Pensacola, FL
    489
    Newbie here, is this only necessary for forced induction?
    69 Suburban Bagged & Blown: http://67-72chevytrucks.com/vboard/s...d.php?t=200387
    68 Farm Truck build thread-LS3/6L80/TVS1900: http://67-72chevytrucks.com/vboard/s...d.php?t=358692
    Advanced Tuner 68Camaro's Avatar
    Mar 2011
    Van Buren, AR
    326
    required whenever injectors are changed. naturally aspirated or forced induction doesn't matter.
    Dec 2006
    Pensacola, FL
    489
    Quote Originally Posted by 68Camaro View Post
    Where do you do this on a 2013 E38 computer?
    Mar 2011
    Van Buren, AR
    326
    I don't think the E38 has this parameter. Ask about this in the gen IV section and you will get more help.
