Results 1 to 20 of 26
Thread: Question about LS3 E38 Custom 2 Bar OS upgrade
    Senior Tuner Iam Broke's Avatar
    Jul 2009
    2,305
    So... someone told me today that the VE table would be all zero's on the custom 2 Bar OS as I load it. (if I understood, I'm old & slow)
    Where do I start on the data for the real VE table when I pull the trigger?
    LS3, E38, TVS2300 9+ psi, stepped headers, no cats full 3" from the headers back.
    I searched the repository for clues, but no joy.
    I tuned SD on an LS1 a few years ago but I need someplace to start I guess.
    '12 Camaro T3 2SS/RS LS3 M6, SLP TVS 2300, Flex Fuel
    Advanced Tuner c.u's Avatar
    Jun 2010
    Eville, IN
    282
    Hear you go.wacth the demo then use the file. http://files.hptuners.com/support/De...alkthrough.swf
    Senior Tuner 10_SS's Avatar
    Mar 2012
    Detroit, MI
    1,320
    Here's a 2010 E38 LS3 for a Whipple 9psi with Whipple injectors BUT slightly modified injector settings, it was good, a little rich in most places. I've been playing with it a bit, but not much so it may "appear" not smooth.
    It will definitely get you running, or something is wrong with the injector settings.
    Stock motor, stock exhaust, etc. Whipple supplied injectors with slightly tweaked injector settings along with a "safer" throttle opening rate setting that everyone with a whipple+manual trans LS3 E38 should have since the stock whipple tune runs lean at tip in between shifts (but not many people seem to care).
    Also fixed is the ~15F difference in Whipple IAT vs. actual IAT temp (verified many times on a room temp ~40F and 75F engine). Still waiting to hear back from Whipple on that as well. Not may people seem to care about that either.
    FYI - the Whipple manifold dramatically changed my VE table, as I converted my VE table from a stock LS3 2010 Camaro E38 using the EQ program, and it's not an ideal smooth VE table, but then again, a Whipple intake is far from "ideal" as there are no runners compared to the stock intake... just a big fan... a radiator, and the intake ports.
    ZL1 Wheels/Tires
    Jul 2009
    2,305
    Thanks for the info, I will look into this EQ program as well.
    Tuner 4evervette's Avatar
    Jan 2008
    dyno room
    169
    If u have good MAF tune ... U still can work from there to build ur VE table...
    specialize in: V8 Conversion & Tuning (UAE- DUBAI)
    supercharge installation
    Salah clutches for Nissan, Toyota and GM car
    Jul 2009
    2,305
    I have the MAF pretty well spot on. WB & fuel trims are +/- 1-2%. I keep the fuel trims slightly neg to keep them out of the PE.
    Jan 2008
    dyno room
    169
    Then u can set up ur VE tables in the scanner and plot ur GMVE values...if u have nice loaded dyno then u can fill almost the whole tables...
    Jul 2009
    2,305
    I understand how to tune the VE tables, thanks. Since the E38 uses the virtual thing and I want to convert to a real one when I upgrade the OS to the custom 2 bar I need a place to start. Looks like the EQ <> VE program will do what I need.
    Thanks again.
    Jan 2008
    dyno room
    169
    If u upgrade to 2.5 Bar u don't need the EQ-VE Program
    Tuner 07MontRedcp's Avatar
    Jan 2007
    Arizona
    187
    Quote Originally Posted by 4evervette View Post
    You can use it to convert the virtual VE equations to a baseline VE table and tune from there, so why not. The custom OS is just a blank table.
    BJK
    APS TT 630 rwhp/654 rwtq @ 9 psi
    '07 C6, TR6060 conversion w/Z06 ratios. DTE Stage 4 Quaife Diff w/brace (3.73). Z06 Brakes, mild turbo cam & dual springs (222/222, LSA 115, .581/.581), LS9R clutch, LG GT2 Coilovers, Autometer Cobalt Fuel gauage, Progressive Alky Controller, and e-Boost2 Controller. PFADT poly bushing for control arms and Sports sway bars. MGW shifter. 3" B&B Fusion. RSI Stage 1.5 fuel system. RX dual valve catch can.
    Jan 2008
    dyno room
    169
    Quote Originally Posted by 07MontRedcp View Post
    BJK
    That's correct ...ifHe starting from complete new tune ...if he is running maf tune ... His SD Coffients are stock and he have to re do them.... Where my point is he can do some data logging using his maf tune to generate the GMVE vaule and use them in the empty VE custom OS ....
    Absolutely nothing wrong of either using 2005 VE TABLE ..or blue cat program... Am just pointing to another way of doing the same thing ...that's all ..
    Jul 2009
    2,305
    Thanks guys. I played with the EQ program last night, while the SLP base file I started with uses the MAF above 900 rpm, I want to have some VE values in the table when I start logging.
    Converted a tune this morning to the 2 bar OS & got my MAP sensor data in there. Played some with the EQ <> VE stuff to get a feel for it. Hoping to get the table built today if it's slow at work.
    looks like the 2 bar OS for my E38 is really 1.75 out of the box and I have a 2.5 bar MAP sensor but I never boost much over ~9 psi anyway (150kPa absolute). Got the fan settings moved over also. Lots to compare between my tune & the Custom OS to see what moves over and what doesn't.
    Senior Tuner DSteck's Avatar
    Mar 2008
    St. Louis, MO
    4,860
    Just edit the axis labels. If you aren't boosting very high, give yourself greater resolution.
    http://www.dsxtuning.com
    Just say no to bull s***.
    Jul 2009
    2,305
    Well, I tried several times to generate a meaningful table with strange results. Some areas are negative and when I paste the tables in I get zeros there. See below.
    Must be screwing something up.
    28,268
    min ve value allowed is 0 hence the reason negative values go to 0.
    Jul 2009
    2,305
    Wasn't expecting any values that low I guess, understand the table limits though.
    28,268
    Yeah I don't understand that either. I've always just recommended using an E40 Corvette/GTO Ve table as a solid starting point.
    Jul 2009
    2,305
    Thanks, I'll search the repository or use the one 10 SS posted.
    Jun 2010
    Eville, IN
    282
    No need to look just use the VE table from the file i posted. Then like the demo shows fill in the blanks.
    Jul 2009
    2,305
    Ok, I took the '06 tune from c.u.& the '10 tune posted frm 10 SS & used the '06 for up to 105 kPa & interpolated the gaps, then pasted in the VE from 10 SS for the areas 110kPa and above with some more interpolation. Looks too perfect, but it should give me a starting point at any rate.
    Now I have to wait for some good weather. Thanks to all.
