Page 1 of 2 12 LastLast
Results 1 to 20 of 23
Thread: Scaled tune vs. Custom OS SD tune
    Advanced Tuner 68Camaro's Avatar
    Mar 2011
    Van Buren, AR
    326
    I have been seeing a lot of Scaled tunes for boosted applications talked about on this forum.
    I would like to have opinions + pros and cons as to which method to tune a boosted application (20+psi).
    I am planning on doing a 88mm turbo build soon and am at war with myself on which way I want to tune this animal. I have tuned a smaller turbo car and did a 2 bar SD tune which worked out nicely but I keep seeing scaled tunes talked about and I don't know much about them.
    Nov 2009
    All Around
    3,149
    depending on your PCM, and your hard coded MAF limits
    Mar 2011
    Van Buren, AR
    326
    Thanks for your response. I was hoping for more responses and a little more discussion/information than what I have received though.
    Advanced Tuner blownbluez06's Avatar
    Jan 2008
    Forney, TX
    982
    There are other limits that you won't enjoy hitting. Even in SD mode, scaling keeps you from hitting airflow ceilings that will put you in reduced engine power and help keep you able to use the spark tables instead of riding the bottom line on the hit. Scale it too small and you won't use any of the table. Scale it too big and you'll hit the bottom airflow line when you hit boost.
    Hsquared racing engines RHS 427, Procharger F2, Moran Billet Atomizer injectors, Alky Control,Mast LS7 heads, Nitrous outlet kit,Tilton quad disc clutch, DSS shaft, RKT56 ZR1 trans, RPM Quaife diff. Built and tuned by yours truly.
    Mar 2011
    Van Buren, AR
    326
    Thanks blownbluez06 for the info. I am assuming the scaling in SD mode you are talking about is still with a stock OS? Upgrading to a 3 bar custom OS will get me to 29.4 psi before limiting out I believe. It seems a lot of tuners will scale the stock OS so they can still use a MAF for better drivability (street manners and mileage)? These are really the questions I am hoping for some insight as to why scale the stock OS instead of just upgrading the OS to a custom 3 bar deal.
    Looks like you are making lots of power (boost). Is your tune scaled or custom OS?
    Aug 2009
    Calibrating
    3,372
    Driveabiltiy and mileage should be the same for either. I prefer scaled MAF Tunes myself
    15 C7 A8 H/C 2.3 Blower/PI
    14 Gen 5 Viper
    Mar 2011
    Van Buren, AR
    326
    Thanks for weighing in Mr. Charles. can you give any pros vs cons between the two methods? I know its just my OCD kicking in but I like to understand (or try to) all angles to try and make the best decision for the application. Thanks again to anyone willing to help a crazy guy out!
    Aug 2009
    Calibrating
    3,372
    Sure, Scaled MAF you can have whatever G/sec limit you want, so a 50% scaled tune, when the computer read 512 g/sec its really at 1024 which from what I have seen is good for around 1000rwhp ( the new GM computer have a 4000g/sec limit) since the tune is scaled the 1.20 limit that's in your computer (gen 3) again a 50% scaled tune makes this 2.40g/cly in your spark tables, so on a low boost setup using SD it will hit the last cell at 1.20 and just reuse it. That might be find at low boost but pushing a lot of boost I like to have full spark control. Something else is you can look at Tq the computer makes if your making big power, the limit in the ECU is 640 in most OS's, so again a scaled tune you can actually see what your tq prediction is, so a 50% scaled tune and it shows 400ftlbs that's really 800.
    What I don't really like about SD is on boost setups the IAT swing is typically ALOT so as the computer sees a high temp it actually leans out the AFR, I have seen a 20 point IAT change AFR up to a point or more. Sure you can mess with the Bias, but to be honest its still a problem (or has been for me anyways) and you can play with the PE IAT multiplier to somewhat counter this, but its a lot more time consuming. To be honest all SD tuning should be done it STEADY STATE, and when you differ from your steady state values you should stop tuning till you get back into steady state, that's really the trick to SD tuning. IF you run the system in CL is helps counter this, but cold starts or warms starts will still be in OL and WOT is always OL.
    Ultimately the computer just looks at either the MAF or the IAT/MAP sensor for fueling, its your choice what you want to use. I feel like the internet made SD so popular, maybe not the really good tuners, but then again some of them like SD tunes lol.
    14 Gen 5 Viper
    Mar 2011
    Van Buren, AR
    326
    Thank you Mr. Charles! This is exactly the kind of information I was looking for. I understand a lot better and actually think I am going to do a scaled tune for my combo now. I have ran into the IAT problem myself with one SD tune that I did - there isn't access to whatever fueling table the IAT is controlling that I could find and it really made things difficult.
    Jan 2008
    Forney, TX
    982
    Quote Originally Posted by 68Camaro View Post
    I scale all high boost, high power applications.
    I see you're in Arkansas and have something that looks like a ProMod. You know my friend, Doc Baker?
    Aug 2009
    Calibrating
    3,372
    Blown does Doc have a red procharged LT1 Camaro?? If so I seen him wear some people out street racing lol
    14 Gen 5 Viper
    Mar 2011
    Van Buren, AR
    326
    Quote Originally Posted by blownbluez06 View Post
    I know of him (Doc Baker). We both race at Centerville Arkansas. I'm not sure what he has running right now but he used to have a blown alcohol Studebaker truck that ran pretty well.
    Mar 2011
    Van Buren, AR
    326
    Just talked to a mutual friend who says he (Doc Baker) is working on a Demon now that's gonna be pretty nasty.
    I have one more question - Do you just use the stock OS or are you guys upgrading the OS and then scaling the new OS?
    Aug 2009
    Calibrating
    3,372
    stock OS, no need to upgrade
    14 Gen 5 Viper
    Mar 2011
    Van Buren, AR
    326
    Quote Originally Posted by Ben Charles View Post
    cool! Thanks for the information!
    by the way - where in Arkansas are you? Do you ever come to the track at Centerville?
    Aug 2009
    Calibrating
    3,372
    Im up in the NE part Jonesboro/Paragould area. No I haven't made it up to the 1000ft track, we are about 1.5 from the Motorsports park in Memphis, that or we do 1/8 stuff local
    14 Gen 5 Viper
    Dec 2008
    on the Dyno
    1,825
    Depending on the power level I scale all boosted tunes normally, stock OS MAF and 2/3bar OS. Gives resolution to the boost region on timing tables because un-scaled 1.2 g/cyl isn't hard to hit. The determining factory for keeping stock OS and custom OS is whether you want to run MAF or SD. Keep in mind the flow through the MAF as well. On a higher boost setup your not gonna run a stock 75mm or 85mm MAF and stay under the 12,000hz frequency of the table in the editor. This will keep you from accurately metering airflow for fueling. You'll have to run a card MAF in a large housing to keep the reported frequency within the 12khz limit.
    Located in Central Kentucky
    ShorTuning
    Aug 2009
    Calibrating
    3,372
    Yea what James said, best to step up to a card style MAF with a larger tube.
    14 Gen 5 Viper
    Jun 2007
    Finland, Europe
    548
    How stable the card-style MAF is? I mean, is it fine with boosted cars, but not that stable with high-overlap cams?
    I don't have any evidende for this, just asking.
    Jan 2008
    Forney, TX
    982
    Custom OS
    Adding the third dimension of boost greatly enhances the ability to properly fuel the vehicle when used properly. If I were on a bologna sandwich budget with filet mignon taste, I might hack up a stock OS, but in no way are the two even comparable. This will, I'm sure lead into a discussion of those who have "gotten away" with hacking the stock OS and while we can get away with it, it's not the best course of action in my opinion.
