Everything except the injectors has changed, new block 347, different static compression, centri-blower, cam, heads, headers, etc... everything. 2bar SD. LS1B ECM.
It will start very easy, however, one must feather the throttle to keep it running. (barely)
What is the most effective way to get it to idle?
the wideband is near stoich near the idle rpm (for the second it hangs there) after that it stalls or when feathering the pedal up to 2000 unloaded rpm, its lean (off the scale) -
Trims are pegged at +25%. lean
Does one just go across the VE table and add 12.5%? and keep doing this until the wideband has a reading other than lean?
How can you log STITs if you are having to feather the throttle?
Does one just increase the idle position to lets say, 2000rpm and get the VE dialed in so at least its running without human help? would this idea even work?
I would like to hear what other options there are in a case like this?
thanks
