Was over at a friends shop yesterday checking out a couple tunes they were having difficulties with. We were discussing gen 4 SD tuning as they had a GTO they couldn't get to fire up correctly after custom fabbing a cold air intake and deleting the MAF. I told them to install an LS3 MAF and tune with that because without a MAF the ECM doesn't know what TPS to target to achieve base running airflow.
Having said that, no MAF in SD tunes with 6L80/90 vehicles throw off shift parameters with the computer unable to calculate torque outputs.
I don't do a lot of SD tunes so I don't have the answer to the question, but is there a way to get rid of the MAF and not have idle and transmission complications? Or is the best method to keep the MAF and set dynamic airflow to max rpm?
