ok so i have been playing with the tune with the help of pat g(he just giving me a little tuning info)..
for some reason at idle the car long terms are 25% so he believes i did not put in the correct injector data.. or i need to look at my fuel pressure.
can somebody look at my tune to see if i have the correct injector data for stock ls6 injectors and also the log to see if anything else i need to check please!!!!!!!!
car is an 2005 cadillac ctsv i just did a cam 227/234 brian tooley stage 2 cam in. long tubes(catted), corsa catback.. stock intake,stock ls6 injectors..
thanks guys..love to get this squared away so i can drive the car to work safely tomorrow!!
Reason: change title
ok i got that problem fixed.. it was a bad vaccum leak..
now tune is closer and better.. tuner said since its alot better i need to adjust the MAF scale at lower Hz to compensate for the lean readings in the lower rpm...how do i go about doing that..
Im learning and i know what things mean just dont know the best way to change them and in what increments lol..
thank you..
I attached the new log from fixing the vac leaks..Let me know what you think
