I am new to this, reading everything I can, and trying to make sense of it, would appreciate any help/advice.
My car is a 1970 Camaro, LS 376/480 GM crate engine (cam specs are 219/228 duration, .525" lift), using GMPP controller package (E67 ECM, and as I understand it, an OS unique to the GMPP crate engines). The attached log was made with the original unaltered calibration from GMPP.
I am using an NGK AFX wideband which has been calibrated in free air according to instructions. The engine has long-tube headers, and all the O2's are in the "collector" area. The air intake is 4", fed by a small scoop below the radiator, and there is an airflow straightening device upstream of the MAF sensor.
I have attached a screen shot of a representive area I would like help with. The conditions are light throttle cruise at around 60 mph. I see AFR's from the wideband in the low 14's--I would guess that an average value would be about 14.3. At the same time, LTFT's are +9-10. If I understand this correctly, this means that the factory O2 sensors are detecting a lean condition and "asking for more fuel". However, if my wideband is correct, with the LTFT's adding fuel it is actually running overly rich. I intend to "calibrate" my MAF sensor using the technique outlined in Dan Maslic's book, but before I do that, I am thinking I need to know that I can trust my wideband O2 sensor.
Any comments or suggestions?
OE WOT + hwy cruise.hpl
Original tune 6-15-13.hpt
6-15-13.cfg
