I'm getting conflicting information on this. I was under the impression that unless the vehicle was flex fuel equipped, changing this table's values would not change lambda and the O2's would think 14.7 was lambda 1. I have recently been told by a very experienced tuner that this is not the case. He told me that I could change AFR to whatever I wanted lambda to be, and the ECM would reference this table and adjust fueling to bring AFR to the value in the table.
I'd like to run 14.2 AFR for pure gasoline, verse 14.7. Or at least give this a whirl, as an experiment to see if fattening up the part throttle, lower rpm cruising would help with some reversion induced surging.
I tried this once before, while monitoring my wideband output, and it continued to report 14.7, even though I changed the Stoic AFR table to 14.2. Fuel trims did not appear to have changed much, if any. But, I did not re-program the wideband lambda 1 setting to 14.2 before I logged this particular run. I thought it would show actual AFR, but now I believe my thinking was in error.
