Since 2.24 came out I decided to get back into running some checkup scans on my car. Good thing I did, I came across a weird occurrence of having a very high AFR Error while in PE. Attached are the scan and two screen shots that show the occurrence happening as well as the scan (frames 2753, 3700)
My question is per the scan this looks like fuel starvation correct and I should begin to look at the fuel pump and filter?
Or is there anything in 2.24 that might have changed since the last release to cause this? I did read in the pcm into 2.24 and then did a write calibration for a change to the idle speed.
Thanks for looking!
