I am wondering why if I am tuning maf only, and VE is disabled, I still get numbers in the histograms of VE.
2007 Corvette C6 Vert. A6
LME LS402, Pat G custom cam, ATI 10% OD Damper
Circle D triple disc 2600, 3.42 Diff
YSI, 3.0 pulley, ID 1000's
Alky Control Meth,
ARH 1 7/8 headers,
1009 RWHP @ 7000, 817 RWT @ 6000
I would think you are still getting data as you are still logging it.
You are logging RPM Map and Lamda Error.
This doesnt mean your Pcm is using VE it is just the data that you have asked to be logged.
That would be my assumption.
Alky Control Meth,
ARH 1 7/8 headers,
If you disable VE, you still have the table in the PCM, so VCM scanner can still reference your VE table, and plot it against your AFR to give you the error. When you disable it, you dont use it, but doesn't mean its no longer there to see for vcm scanner and plot against it.
Hope that helps
