I'll let Dave confirm here, but you should have everything in that OS. The issue I had seems to only exist with the 10+ Cameron's. And it only required some clever wiring changes.
Curious if the diagram you included is accurate with your later findings for the Camaro wiring. I bought this module from Dave and I'm going to install it on a 2012 ZL1 Camaro
12' CAMARO ZL1
Brian Tooley Racing, ID850's, NW102, TR7ix, Ported Snout, Blower, Airaid CAI, LPE 2.55" upper, Metco 9.55" lower, Meziere WP136 HX Pump, KD Innovations HX, Coolant Tank, Saikou Michi, IW Balancer, Stainless Works 2" headers w/High Flow CATS, Kenne Bell BAP
Can you give a link to the diagram relay? I cant seem to find one. When I search dpdt relays they are either both off or both on. Thanks
