Page 1 of 2 12 LastLast
Results 1 to 20 of 22
Thread: Timing retards with WOT and RPM increase
    Tuner Roundhouseman's Avatar
    Apr 2013
    Tafton Pennsylvania
    81
    2009 Colorado 5.3L 4L60E. I have removed torque management, set PE at 2.0, added 2* to the High & Low octane tables and a few other minor changes. Here is a snapshot of a WOT. My cfg and log files are posted in the getting started section. The calibration file has been changed. I got rid of the KR by changing PE to its max. Not sure what to do with the timing issue with WOT. Is it normal? The butt dyno feels it needs improved... All is stock but the cat's are gutted out, rear O2's are off. Any help out there??? Thank you!
    Apr 2013
    Tafton Pennsylvania
    81
    Here is another snapshot. 12* advance??? I don't get it........ Feels like there should be allot more power.
    Feb 2009
    1,931
    Check out your iat's during the run, they are up there. There is a table that pulls timing based on iat to avoid knock. Pretty sure thats where your timing is going, check the table out and see where you are running on it.
    Apr 2013
    Tafton Pennsylvania
    81
    Quote Originally Posted by mecanicman View Post
    I was wondering that. The IAT is part of the MAF. It wasn't EVEN that warm out today.
    Apr 2013
    Tafton Pennsylvania
    81
    IAT Spark table
    I guess I need to check out the IAT/MAF to see whats cooking!
    Nov 2009
    All Around
    3,149
    post your tune
    Apr 2013
    Tafton Pennsylvania
    81
    Here is my latest tune and log. Thank you! Steve
    Steve's 6-3-13 Colorado V8.hpt6-3-13 1353 pm Colorado-3.hpl
    Nov 2009
    All Around
    3,149
    the way how you have the IAT spark set-up its pulling 6* at that temprature in your log 109*F
    you need to log airmass g/cyl to see at what load your engine is at. also since zero out the Variable Cam spark since its disabled.
    you also still have lots of torque management still on, and that can cause as issue with timing.
    log PID advance torque management.
    Apr 2013
    Tafton Pennsylvania
    81
    Is there hidden Torque Management tables? Where/what do I look/change? How does this look for a cfg. to log?
    Uploaded with ImageShack.us
    Apr 2013
    Tafton Pennsylvania
    81
    I changed the Chart Configuration also to show the two PID's. I'll go do a log and post it.
    Apr 2013
    Tafton Pennsylvania
    81
    Quote Originally Posted by SultanHassanMasTuning View Post
    Zero out all values in the Variable Camshaft section?
    Apr 2013
    Tafton Pennsylvania
    81
    Freeway run log & cfg
    Here is a log of a run down the freeway and then side streets home. There is some Torque management activity but not much? How do I find where its coming from. There is also a brief time of KR when going WOT, down shifting at speed. My goal is better economy if I can be guided that direction.
    Steve's 2009 Colorado V8 6-5-13.cfgSteve's Colorado 6-5-13-2.hpl
    Apr 2013
    Tafton Pennsylvania
    81
    High IAT tem solved
    The small boot between the air box and the fender was removed thinking it would help with air flow. The intake was actually taking in hot air from the engine compartment. I put it back in and now the IAT reads just above ambient temperature. A lesson learned......
    Jun 2013
    18
    where is that timing table at?
    Nov 2009
    All Around
    3,149
    usually its under spark Advance TAB above Misc lower middle of the tab
    Apr 2013
    Tafton Pennsylvania
    81
    Sultan, can you offer any sugestions for me to change based on my last log file or do I need to log some different PID's?
    Apr 2013
    Tafton Pennsylvania
    81
    I did a log and ETC TQ management type is picking up TipIn. I added Fuel and spark TQ Man type and will log in the morning.
    Apr 2013
    Tafton Pennsylvania
    81
    Here is a log from this morning. I added timing to the IAT, High Octane and low octane tables. I am still getting Trans showing Spark TqMgn. I don't know what else I can shut off.... I'm also getting TipIn but it seems to be when coasting or decelerating.
    Steve's Colorado 6-7-13-2.hplSpark TqMgt type 6-7-13-A.PNGSteve's 6-6-13 Colorado V8Timing tables changed.hptSteve's 2009 Colorado V8 6-6-13 2100.cfg
    Apr 2013
    Tafton Pennsylvania
    81
    This is the latest tune with adjustments. I haven't flashed it yet. Can you take a look at the spark tables and the IAT spark table.
    Steve's 6-8-13 Colorado V8Timing tables changed.hpt
    Apr 2013
    Tafton Pennsylvania
    81
    Do these fields need maxed out?
