Specs:
2001 Camaro SS
6.2L L9H (from 09 escalade)
LS3 intake
LS3 rail and injectors from 2010 Camaro SS (injectors 341 model no.)
Cam: 226/234 lobe sep 113* .598/.601
NGK TR6 plugs
104mm fast toys lid
TSP 100mm MAF
90mm Aftermarket TB
Griffin 3in Radiator
Hooker LTs
Tuned on two different occasions by a professional tuner with the same issues. Random lean condition only at WOT... PE is commanding rich 11.7 (for testing) and it hits 12.0 and climbs from there up to mid 13s. The car stops dead in its tracks once the AFR starts to climb and it almost feels like its missing and it does not ping.
I tuned the VE table within +-5% LTFT (SD) and I then I tuned the MAF with LTFT. I then matched the Dynamic air pretty decently to the MAF. It idles pretty solid and it cruises around 14.7-15.0. Very smooth transitions through the rpm levels.
The AFR is set to 14.63 and I have PE kicking it way down.
Fuel pressure when last checked with a window mounted fuel gauge was 58-60 psi.
You can see the AFR go crazy at 7:21:202 in the attached log file and my tune file is included. There are a couple more WOT runs in there as well...d
PLEASE HELP!
finallog-maftuned-pe.hpl
AFTER_VE_TUNE-LTFTADJUSTMENT-8.hpt
