Results 1 to 4 of 4
Thread: Air/Fuel Ratio Meter
    Oct 2012
    22
    If I want to connect wide band O2 sensor to hp MPVI pro interface for tuning VE long/ short trem on the road, which brand is best to use (wide band O2 sensor brand)?
    May 2010
    250
    I am now using the NGK AFX powerdex. Quick simple and easy to install.. I also have the FAST dual wideband. NOT a fan of it anymore.. to much trouble with it and its not as accurate, there is no way to calibrate it.
    Oct 2012
    22
    Does they connect to hp tuner interface?
    Oct 2009
    321
    the NGK AFX does very easily. if you look in the Enhanced I/O subforum, there are plenty of threads that cover getting it set up in the scanner.
