Results 1 to 10 of 10
Thread: Optimum engine temperature for the best fuel atomization and hp???
    Advanced Tuner printmanjackson's Avatar
    Nov 2009
    USA
    412
    I see lots of guys using 160* thermostat with engine temps running around 180*. I changed to an 180* thermostat with engine temps running around 195* now and I have no dyno to back it up but it seems to run better. Has anyone done any testing to back up and proven running these cooler engine temps?
    '02 Corvette
    LS6, MN6, LT's/X pipe and TI's, Honker CAI, AI 243 heads, PatG Custom Cam, FAST 102, LS2 TB, Red Top inj, HPTuners & NGK/AFX
    Apr 2009
    613
    Every LS aluminum block motor I've seen on a dyno always has more hp on the second pull when the coolant temp is 200-205
    Quote Originally Posted by flame View Post
    totally true, they like 200-215 for sure
    Nov 2009
    USA
    412
    Why do I see all these guys selling "mail order tunes" telling everyone to run such a cold engine?
    '02 Corvette
    not sure, i even run my turbo cars with the stock thermostat.
    Senior Tuner DSteck's Avatar
    Mar 2008
    St. Louis, MO
    4,860
    210 is the sweet spot from what I can tell.
    http://www.dsxtuning.com
    Just say no to bull s***.
    Senior Tuner 10_SS's Avatar
    Mar 2012
    Detroit, MI
    1,320
    Whipple includes the 160 thermostat with their kit on the LS3, but coolant is about 180F like everyone else. Do you'all think 200-210 is also better for top mount superchargers? I would check on the dyno, but the owner doesn't really want me changing it. Thinking 20F more degrees will add ~10-15F more during heat soak.
    2010 Camaro LS3 (E38 ECU - Spark only). MS3X running complete RTT fuel control (wideband).
    Whipple 2.9L, 3.875" Pulley, kit injectors, supplied MSD Boost-A-Pump, stock pump
    LG Motorsports 1 7/8" Headers - No Cats, stock mid pipe with JBA Axle Back
    ZL1 Wheels/Tires
    Nov 2002
    Central Florida
    2,503
    I think you want as much temperature, as won't diesel under
    any condition. Then you fit your timing to it. But for simplicity
    you may as well stick with the stock range and concentrate
    more on the real limitations to heat throw, which is where
    your top end of the observed temp range, comes from. The
    thermostat is only responsible for holding up the bottom.
    Senior Tuner Iam Broke's Avatar
    Jul 2009
    2,305
    Quote Originally Posted by 10_SS View Post
    LS3, SLP new style TVS2300, 9 psi, stock tstat, 196* coolant, 105 - 112* IAT's in 90* ambient. 120*f in a hard pull. 16* advance at 6400 rpm, no KR, but I'm on E85.
    I know it's apples to oranges, but maybe you can compare.
    Nov 2009
    USA
    412
    nuff said
    '02 Corvette
