Im having a wierd issue on this car with the 2bar SD OS upgrade.
The car is a 2008 corvette A6 E38 T46. I just finished building the twin rear mount setup and have been running it on straight MAF. Ive had no issues with this other than the occasional random flash that does not allow the car to shift out of 2nd gear. Must be a bug somewhere still. "goes away after a reflash
Anyways, the car runs awsome and tuning is straight forward when using the stock OS in MAF only. I can put the car into SDCL mode on the factory OS as well and it runs fine just a tad on the rich side. I messed with the Virtual VE software for a bit but it seems to just be a patch to me for dialing in certain areas so I upgraded to the 2bar SD OS for the dual PE tables and tps multiplier.
I used the VE table I generated off the factory OS to fill the three new VE tables and checked that the MAF Hz were still scaled the same. Everything looked good so I applied the new OS with Write Entire. I then disabled MAF mode with the Rpm boundaries and the Hz table. Did a flash cal and tried to crank it. It starts for 2 secs and dies... Wide band read 12.8 initially under cranking and made its way up to 14 right when it dies. So I went back and put it into MAF only mode still on the 2bar SD OS to see if the VE table just needed some work. The car starts and idles, but at 1800 rpms it cuts fuel, goes into limp mode, and dies, also my fuel trims are out of wack again. I looked at this very close and it doesnt follow any of the rpm or map boundaries for dynamic airflow. Then looking closer I saw it would fail the maf at that RPM every time for a split second then show -4- in MAF sensor state on the table display for a few seconds then revert back to "no fail" MAF mode after the car was dead. I thought it had to be a VE table issue at this point since the car would die as soon a it hit SD mode every time.
Sooooo I spent the next 3 hours adding and subtracting up to 50% fuel from the VE tables in 10% increments but had no luck. So I went back with factory VE tables and did the same procedure to the TPS mult table... still dies every time the maf fails. For grins I set it up for MAF only on the SD OS and started it again. This time while it was idling I used the scanner to turn force openloop. The car didnt die, but due to a couple multiplier tables I looked past it was commanding a 12.82 afr and it ran fine at 12.82 afr all the way back. I pulled the log up and the wideband showed a lean condition in lower map and rpm areas but by less than 20% and only around idle or off throttle rolling "lean meaning leaner than commanded". Everywhere else there was 7% error or less. So just to test theory I pasted this information into the VE table, forced SD, and it made no difference. Tried the TPS table, still nothing...... WHAT IS UP????? am I a complete moron or just missing something simple here?
Edit: I adjusted the OL mult tables and forced OLSD in the tune it will commanded 14.78 in OL but will not run for more than 5 seconds. Only drivable if you command OLMAF...?
