04 gto engine swapped into an rx7..t56 etc
car is running around 14.xx to 15.xx or 1.2xx in the pe table, we'ved played with the engagement rpm, thresholds...basically everything i can think of... i've even thrown 30% more fuel into theVE table
most of the ve table apparently pretty good for low load cruising, but when you go to WOT... it just goes to close to stoich sometimes leaner.
played with the pe enrich, pe throttle, the hot select,eq ratio etc, after logging the commanded is 12.1 and the equivelancy both read properly...there is a 300 rpm portion of the high load no vacuum afr looks like it's probably right until 2400 or so and then it leans out again!
Any thoughts>
wot-nope-enrichment3.hpl
sept22-13-playingwithwot 3.hpt
wot-nope-enrichment.hpl
wot-nope-enrichment2.hpl
gtopoweredrx7.cfg
