ok i have a mad scientist idea which i have tried on megasquirt but was wondering if anyone saw a problem doing it on a e38. i wanna run stock injectors and a set of 80s. the stock injectors would run the engine anytime not on boost and the 80s would flow at anything above 2 psi. the 80 would have a switch wired inline with the power side. the switch would turn on the 80s at 1psi of boost giving me the size injector flow i need for my boost level. would the injector driver in the ecm handle running 16 injectors and does anyone see any problems with this set up.
