Have a few questions about tvs1900 and magnavolt system
I jsut purchased a tvs1900 magnacharger. Im supposed to use the magnavolt system but do not want to cunt and tap wires and such. My understanding is this is simply a voltage increase for the stock fuel pump. Can this be tuned out so I do not need to use the box.
Thank you .
you would need to tune your vehicle in all aspects, increasing your fuel pump delivery is not tuning.
MAF transfer/ or Speed Density
Ignition Advance Adjustment
Idle and Startup parameters
Injector swap with calibration
at minimum is what you need to do.
best of luck
I well aware of that .. its not going to tune itself haha, guess I should be more specific.
Is that ALL the magnavolt does is increase fuel pump voltage ? And if so is there a table of somesort that I can use to increase the fuel pump voltage ? If not is there a formula to modify injector tables to simulate this ?
