Results 1 to 3 of 3
Thread: single bank fueling on e38?
    ok so my question goes
    if one were to modify the injector bank select (under engine/fuel/general) so all the cylinders are on bank1 (which is 0 in injector bank select)
    and then remove the bank 2 o2's, and put the bank 1 o2 sensor after an exhaust merge (before or after the turbo) or better yet use the wideband that is already after the turbo to simulate a narrowband signal .......
    would said person have closed loop fueling control on all cylinders via bank 1 / bank 1 o2 sensor?
    Jan 2016
    bendigo australia
    37
    I’m curious to find out the correct answer to this as I run an o38 single turbo and a single 02and one bank runs hotter on the pipes than other
    Feb 2015
    Perth, Australia
    974
    ive never used only 1. always 2.
    ive always put them in the dump pipe. I have found with several cars the turbulence in the dump causes on sensor to have +STFT and the other -STFT. this is only at idle and light throttle. as soon as some gas flows they come good. I generally just do them in full open loop SD
