Wondering if the column temps will ever be made so we can edit them?
Need fans on at lower temps with 160* stat.
I searched but no joy.
OS 12649046
OS 12649046
Bummer.
Thanks Bill.
Custom OS has modified labels.
FWIW, you'll make the most power around 210*.
http://www.dsxtuning.com
Just say no to bull s***.
Figures since I swapped in the 160. It's running around 176* at cruise but helped the top end KR. 8-9 psi at 15* on E60 now, no KR. IAT's climbing into the low 100's.
One of the reasons I went to the upgraded OS was for the fan settings.
I thought I knew something about cars, but I cant wrap my head around this thermostat thing. I have a 160, and thought all it did was open sooner, not change anything about operating temperatures. Am I crazy ??
2007 Corvette C6 Vert. A6
LME LS402, Pat G custom cam, ATI 10% OD Damper
Circle D triple disc 2600, 3.42 Diff
YSI, 3.0 pulley, ID 1000's
Alky Control Meth,
ARH 1 7/8 headers,
1009 RWHP @ 7000, 817 RWT @ 6000
It opens at a lower temp so you get coolant circulation to keep op temps cooler. Once stopped though with out lower fan settings temp rises until the fans come on (at 192* in my case). When moving again it drops back to 175* or so.
I've read the debates on the LS3 as far as if it helps or not, just wanted to try it. It's a 10 min swap.
Dave says peak power is at 210* so since I can't lower the fan turn on points, I'll prob swap back.
Still doesnt make much sense. If your stat opens at 160, or 180, you might stay cooler a few minutes longer, but eventually you will rise to the same temps. I see the same temps after running awhile as I did before the change of stat. Lowering the fans on temps has helped run cooler, but that would be with either stat.
Alky Control Meth,
ARH 1 7/8 headers,
If lowered stat & fan settings didn't lower your operating temperature you need a larger radiator. It should.
Lower fan setting keep it from getting to hot. I'm just saying for me, the stat alone didn't change much.
Alky Control Meth,
ARH 1 7/8 headers,
ls engines don't like being cold. i made the most power at 205-210 ect's vs 180 degree's. fwiw
all else fails. set the lowest temp cell to 50-75% and follow it up with the rest of them like this till it commands 100%
The most hated, make the most power.
93 Ranger. 5.3 D1X. 1069hp.
Ok, I'll be swapping the 160 out soon. 2 votes against the 160 in one thread by my idols... lol.
