So I just Installed my On3 Performance Non-AC Turbo kit on my 2000 Trans Am. Stock long block, Double Valve Springs, Hardened Push Rods, LS6 Intake, FIC 60# Injectors, Racetronix 255 with Wiring Harness, On3 76mm Turbo, 2002 OS with 2 Bar OS. I tuned my car 2 Years ago when I was full bolt on and had no issues, Car ran flawless. Now that I am Boosted its kicking my Butt. Rich idle, Runs real rich under load, Cruising it's okay sometimes(near stoich). I'm Not sure if my injector Data is correct, I've got mixed opinions on that. My Injectors flow tested @ 666cc(62LB)@43.5PSI(3Bar) According to the Data sheet that came with them. I've tried doing VE tuning but I'm Concerned that i do not have the basic stuff correct Because I'm not seeing much change.
Can you all look my tune over and help point me in the right Direction. Sorry for my ignorance I will fully admit I'm a noob when it comes to tuning.
