Car: 2007 Cobalt SS/SC
Mods: intake, ls4 tb, pnp sc, h/e, 2.8 pulley, 60's, catless dp & exhaust
While tuning in open loop the car runs fantastic, perfect afr all around!
When put in closed loop, the trims were a bit off still. So we did a few logs and tuned them down. While cruising around the gauge will randomly go into the 17's and just stay there. He has to give it some gas, not quite full throttle, but peg it real quick to get it to go back to normal. I figured it was just the full trims needing adjustment. So we just kept adjusting and eventually the trims were fairly close, didnt finish due to getting late and he needed to leave, but still within 2-3%.
When looking at the logs, his trims are in the negatives which would mean he is running rich, but the gauge is showing it running in the 17's at some point...
When we first met up, his car was wistle to it, sounded turbo'd actually. I think it is an exhaust leak, but he said he thinks its his tranny. What do you guys think could be the issue? If it is in fact an exhaust leak, then I think fixing that will solve our issue. I am at work now, I will post the tune and my last couple logs up when I get home.
