Page 8 of 11 FirstFirst ... 4567891011 LastLast
Results 141 to 160 of 219
Thread: Tuning the 1.4t Cruze - A Mildly Scientific Approach
  1. #141
    Nov 2007
    Minnesota
    555
    I zeroed out the 8 cylinder row, no dice, still "knock". Fuel trims are -3%. Weird.
    2012 Chevy Cruze A6 1LT RS
    Formerly - 2004 GTO, 2002 Z28, 2007 Colorado, 2008 Silverado
  2. #142
    Tuner snowvette's Avatar
    Oct 2008
    Rockford Il.
    135
    I bought a set of those "Magic" spark plugs. When I swap them out, I plan on doing before and after logs to see if there is any reduction in light load KR. I still have a little just cursing at a constant 65mph. Just little blips of 1 to 2 degrees.
    Annoying.
    2007 Chevy Trailblazer SS AWD with boltons GP tuned
    2012 Chevy Cruze A6 LTZ RS Vermount Stade 0 tuned
  3. #143
    Nov 2007
    Minnesota
    555
    Quote Originally Posted by snowvette View Post
    Annoying.
    That sounds like what I'm getting too, almost always above 60mph. In regards to those plugs, I've been doing reading and apparently they are good for turbo motors, so they may help.
  4. #144
    Oct 2008
    Rockford Il.
    135
    Well, I put those plugs in Sunday gapped to .030. I had the stock plugs gapped at .032 and had blow out a few times. I seem to be getting a little more blow out with the new ones. I'll tighten them up a few thou and give that a try.
    Mid range throttle response is a lot better. But no reduction in KR just from watching my Dashhawk. Still a couple degrees here and there. If tightening the gap gets rid of the blow out, then they will be a great improvement.
  5. #145
    Feb 2011
    11
    Hey Snow, how much boost are you seeing when blow out becomes a problem?
    Also, you guys are tuning automatics, what RPM does the torque converter stall at?
  6. #146
    Oct 2008
    Rockford Il.
    135
    I'm not sure if its the weather change or what, but I never used to see any higher than 20 psi. Yesterday morning I saw 22 psi twice in 3rd gear.
    I dropped the gap down to .025, will see how that works.
    I can foot break to about 2500 rpm and that builds a little over 5psi of boost.
  7. #147
    Nov 2007
    Minnesota
    555
    Haven't logged in ages. Going to start seeing if VVT changes affect the top end power at all. Can't find the plugs anywhere so I haven't tried them yet.
  8. #148
    Oct 2008
    Rockford Il.
    135
    Autozone was the only place out of four parts stores that had them.
  9. #149
    Nov 2007
    Minnesota
    555
    Damn this car is so frustrating with the knock. It is ONLY light throttle after cruising. If I hit the throttle "hard", no problem, no knock, nothing. It is like a transient fueling issue where the car starts to lean out and then is really slow to get back when you hit the gas again in a mild manner.
    I really want to get rid of this thing and get maybe a Ford Fiesta ST, will never happen because I'm so upside down. Went to a dealership the other day for another car and the best they could offer me was $13.5 . What a joke!
  10. #150
    Oct 2008
    Rockford Il.
    135
    Holy ****, that's to funny. I did the same thing last week. Tryed to trade it in on a 2009 G8 GT. $13k for mine with 62,000 miles on it.
  11. #151
    May 2013
    Miami, FL
    5
    Quote Originally Posted by Blue Angel View Post
    Related note, what adjustments must be made to get that stall? Stock stall is only about 1500 on my Sonic 1.4T/6A and it's dead off the line until it builds boost.
    Quote Originally Posted by Gh0st View Post
    I'm guessing you have the PE enrichment rate set high right? If not try going to max and see if it stops it from having that tiny lean moment.
  12. #152
    Nov 2007
    Minnesota
    555
    Quote Originally Posted by Italianjoe1 View Post
    It's not an issue with PE, there's something else either mechanically or within the tune. The only time I ever get knock is when cruising, which of all places I should not be getting knock. I've been battling this since May of this year, see this post -
    http://www.hptuners.com/forum/showth...l=1#post322193
    It happens no matter how much timing I add or pull, it is always the same knock retard.
  13. #153
    Nov 2007
    Minnesota
    555
    How is it with the gap lowered to .025? Isn't the max GM spec for the plugs .28 anyways?
  14. #154
    Oct 2008
    Rockford Il.
    135
    .025 fixed it.
    I'm not sure of the GM spec.
    I ran the stock plugs at .034 and they were ok most of the time. I never tryed stock plugs and being tuned at a smaller gap. Probably should.
  15. #155
    Nov 2007
    Minnesota
    555
    On stock tune and trying to get all the knock retard out. Three different tunes now, get knock retard on every single one. I'm down 3 degrees from stock in a lot of acceleration cells and I'm running what is supposed to be 93 octane....
  16. #156
    Nov 2007
    Minnesota
    555
    Quote Originally Posted by smithers View Post
    No knock.
    Do you mind posting your tune? I'm ALWAYS getting knock when accelerating.
  17. #157
    Nov 2007
    Minnesota
    555
    There is no way in hell this isn't false knock.
    1. No matter IAT, always knocking.
    2. No matter fuel. I have run 91 and 93(even filled up at a different Amoco today).
    3. STOCK tune!!!! So now extra boost or requested power.
    4. Always while cruising and giving throttle from a cruise.
    This is NOT RIGHT!!
    [IMG][/IMG]
  18. #158
    May 2006
    Seattle, WA
    539
    Can you tell if it's burst knock or regular? (I admit Ive just been scanning/monitoring this thread)
    Still, especially on premium thats really weird...
    ~Erik~
    2013 Sonic RS - manual, CGM, 6M, sunroof, mods in process
    2008 TrailBlazer 3SS AWD LS2, loaded, dropped, modded, SE22 Performance tuned. And then some...
    2002 TrailBlazer LT 4WD 4.2L I6, lifted, tires, exhaust, SE22 Performance tuned
  19. #159
    Nov 2007
    Minnesota
    555
    99% it's not burst knock. Yeah it is really weird, really damn annoying too and the primary reason I want to get rid of the car....sad.
  20. #160
    May 2006
    Seattle, WA
    539
    Have you put it on a dyno and used some muffs to see if it's actually knocking? Could be an issue with knock sensor sensitivity.
    ~Erik~
