I have a strange instance happening on the dyno. The car will not make a WOT pull without getting into a "Cut" scenario.
All I can see happening in the log is a HUGE jump in injector duty, followed by a large drop in duty, and so on for as long as I let it continue.
This car made several clean pulls yesterday, I broke for lunch, then came back and it was acting up. I litterally cannot figure out why, as I didnt make any tune changes between the last clean pull and the first bad pull.
Here's a tune file and log. The tune file is basically a quick slap together file that I am using to try out disabling different limiters.
So far, I ruled out all torque management, Burst knock, regular knock, etc.
I also noted on one of my logs that engine torque goes through the roof simultaneously with the injector duty. Ive even tried messing with the max torque timing table to see if I could get the reported torque to come down. No luck there.
Im thinking its just something stupid that Im missing. Please help me get this car rolling. I only have until 5 today with the dyno rental.
Almost forgot, car is a 2010 Camaro SS/RS with the L99/A6. Running 60# shorty's, ZL1 fuel pump, and a Granatelli Twin Turbo System.
