Originally Posted by
Ben Charles
Fix the MAF for Fueling not just the PE table, I'd run that setup high 11's AFR for more power and tq. The Spark tables are in g/cyl not g/sec, and with that setup I would bet you should be maxing the 1.36 G/CYL limit. You can probably fix the axis on that table to read more though.
As far as the MAF, what the other guys said. I personally had a Procharged setup with the MAF right after a 90 degree bend, couldn't tune around it till I moved the MAF further downstream into a straight in/out section.
