Originally Posted by
doc350
At wot, the car is fine. AFR is right about 11.3 or so. However, while at cruise, the AFR fluctuates the entire range of my wideband. (NGK AFX) This is while tuning in open loop/maf only. It does it in SD as well.
If I make a change to the maf curve (or VE calculations), it doesn't seem to have any effect on the way the car runs.
Is there something I'm missing? I've done a couple of these kits on manual trans cars, so my thought is that there might be something in the transmission tables I'm not seeing.
