As the title says... do any of the newer ecu's support 24x cranks
Was the 05 ls2 a 58x with 4x cam ? I remember one of them having a 1 x cam gear for some reason ?
Anybody ?
Anybody ?
The E40 suppoorts 24x crank 1x cam signals. It was used in the first LS2 cars that did not have 58x/4x signals.
2023 Durango Hellcat
MikeOD is correct, E40 was a short lived ECM that served as a transition for GM from Gen III to Gen IV. An 05 LS2 will have a 24x/1x reluctor setup and would have come with an E40. 06 LS2 in a Vette would have 58x/4x, every other LS2 for 06 was still 24x/1x (in the US). 07+ were all 58x/4x.
~Erik~
2013 Sonic RS - manual, CGM, 6M, sunroof, mods in process
2008 TrailBlazer 3SS AWD LS2, loaded, dropped, modded, SE22 Performance tuned. And then some...
2002 TrailBlazer LT 4WD 4.2L I6, lifted, tires, exhaust, SE22 Performance tuned
Very interesting thank you for the response .
So would the e40 be a good ecu to boost ? and do i have to run a separate tcm ?
Mainly are the spark airmass tables scale able ?
Yes on TCM required. Spark airmass axis. Doesnt appear to be editable.
You can scale the entire tune however to get around the 512g/sec airflow limit and will increase the headroom you have on the spark airmass table as well.
James Short - [email protected]
Located in Central Kentucky
ShorTuning
Right ... but it will become a tuning nightmare and throw off all other tables .... and it probably wont report correct injector duty cycle right ?
http://www.dsxtuning.com
Just say no to bull s***.
