Results 1 to 4 of 4
Thread: EIO and LNC-2000
    Tuner in Training Blazonic's Avatar
    Jan 2008
    Santa Fe, Tx
    21
    EIO and LNC-2000
    I am hooking up a LNC-2000 and wanted to monitor the timing retard function through the HP Tuners. The instructions of the LNC-2000 says it outputs analog 0 volts for 0 degrees and 3 volts for 15 degrees retard. How would I set this up in the EIO section of the HP Tuners?
    Also, I have not kept up with the latest 2.24, are you able to data log EIO without a laptop yet?
    You want how many from a BLAZER!? Its a F*cking SUV. it just looks fast, HONEST
    Jan 2008
    Santa Fe, Tx
    21
    Just checking I set it up right. I took the 3 volt max, and the 15 degrees max retard and divided the 3 by 15 which gave me .2 so in the user defined EIO I set up a voltage unit with a 0.2. Is this correct?
    Potential Tuner swoop's Avatar
    Jul 2012
    Clackamas Or
    8
    Thats how I did mine but it seems to read 1 degree more retard than what I have in the LNC. I've been wondering if there is a better way to set it up myself. Hopefully somebody that knows for sure will chime in.
    Aug 2008
    Shawnee,kS
    81
    you can log without a laptop now with 2.24. analog is finally re enabled
    1998 Pontiac Trans Am - 1000+ rwhp street car
