Results 1 to 11 of 11
Thread: 6l80e TCC Slip
    Aug 2011
    30
    6l80e TCC Slip
    Hey Guys,
    One thing I'm still trying to remidy is a TCC Slip issue, if you look at the attached pic you can see at 60%+ throttle the TCC Slip (rpm) and Turbine RPM both are erratic while in 3rd gear, this isn't from tire slip.
    I have a Century built A6 and Yank 3200 Stall, I suspect I have to increase pressures, just dont know what ones, any ideas?
    Attached Current tune file as well
    Cheerz
    Steve
    SteveC62BarPE03MAF10Spark36Trans39.hpt
    2008 Corvette C6 A6
    E force 599HP kit, 3.25 pulley
    ZR1 Cam, ATI Balancer
    160 stat, Dewitts Radiator
    LG 1 7/8 Superpros, delete cats, xpipe
    Century Built 6l80e, Ext. Transmission Cooler
    3200 Yank
    2.73 rear
    Does it do the same thing during light load? Or just when you load the car up more in the higher gears?
    Aug 2011
    30
    Happens when throttle above 60% (450-500 ftlbs tq) noticed it also on 2nd gear as well. Have the Traction control to Competition mode, driving feels like its being held back and released like when Traction control is on and you get wheel spin.
    2008 Corvette C6 A6
    3200 Yank
    2.73 rear
    Jun 2011
    Montreal, Canada
    758
    I had the same issue. Log missfires and I bet you are showing some. Missfires will cause the converter to unlock. I raised the missfire tables 10% at a time in the areas I was showing some, until they didnt happen anymore, and the converter stays locked since then. Some people max the tables but I wouldnt as I still want to know if there are any real missfires.
    2007 Corvette C6 Vert. A6
    LME LS402, Pat G custom cam, ATI 10% OD Damper
    Circle D triple disc 2600, 3.42 Diff
    YSI, 3.0 pulley, ID 1000's
    Alky Control Meth,
    ARH 1 7/8 headers,
    1009 RWHP @ 7000, 817 RWT @ 6000
    Jun 2011
    Montreal, Canada
    758
    After looking at your tune I realize your converter is not set to lock in any gear.
    Alky Control Meth,
    ARH 1 7/8 headers,
    Aug 2011
    30
    Will start loging misfires and see what comes up, the Convertor is set to lock in 5th and 6th and does so in a manner that works for the 3200 stall
    2008 Corvette C6 A6
    3200 Yank
    2.73 rear
    Jun 2011
    Montreal, Canada
    758
    Quote Originally Posted by mrgillies View Post
    You are right. My mistake. I would check misfires, and if not that I would raise the rgulator offset to 90. You should be getting more pressure when locked. Last thing I would try is the apply ramp. With the offset at 90, you should see 109 psi which keeps it locked tight.
    Alky Control Meth,
    ARH 1 7/8 headers,
    Aug 2011
    30
    Looks like misfiring is the issue, cylinder #3 has 60 misfires in 1 sec, with#7 with 4 and #8 with 6. The rest are at 0.
    Guess its time to check the plugs and injectors, Now is also a good time to do motorhead47 fuel mod to supply fuel to the rear of the eforce.
    2008 Corvette C6 A6
    3200 Yank
    2.73 rear
    Jun 2011
    Montreal, Canada
    758
    Chances are good they are not real miss fires. Double the numbers in the miss fire table and they will probably stop showing. Mine did. Headers, cams, converter, can all cause this. Feeding both rails is a good idea anyway.
    Alky Control Meth,
    ARH 1 7/8 headers,
    Aug 2011
    30
    Quote Originally Posted by realcanuk View Post
    Well, one of my spark plugs (#3) had a creacked ceramic stem, possibly due to the stock cable boot rubbing against the headers, put in a temp Iradium spark plug as dont have any spare (cooler) NGK TR6IX lying around, ordered some 8.5mm MSD plug cables as well, may as well do it right, should have done it as soon as I installed the headers.
    After a few runs, the misfires have reduced dramatically, now time check if the issue has gone.
    Steve
    2008 Corvette C6 A6
    3200 Yank
    2.73 rear
    Jun 2011
    Montreal, Canada
    758
    Steve
    Glad you found the issue. Personally, I dont hear great things about MSD wires and run stock ones with koolsox on them and have had no issue with them. Either way, even when you fix that up, you should raise the missfire tables a bit because a cam and torque converter will always give you some false signals, and as you see prevent the converter from locking.
    Alky Control Meth,
    ARH 1 7/8 headers,
