Hey Guys-
I've recently purchased a G8 with the 6.0. I've also purchased an LSA supercharger set-up for it. (Measurements say it will fit, except maybe having to do something with the hood bracing). Looking to run around 10 psi for now.
I do have a few questions:
The IAT sensor presently resides in the MAF. I know most of the aftermarket kits have you clip the wires and move them to a post SC screw in sensor. Is the stock IAT sensor on the LSA a 5v sensor that I can do this trick with? (Or could i even wire it up to work as an IAT2 sensor and have both?)
Can the MAF sensor on a G8 handle a forced induction set-up or am I going to peg it and need to swap it?
I suspect i will either have to go MAF only or upgrade to the 2 bar custom OS?
I guess thats all for now. Thanks guys
