i have a 95 lt1 with lt4 hot, cam ported heads, manley valves, 1.6 rollers, stock bore & stroke, pulleys, headers, k&n, ported throttle body and mass air, built trans, 3.73, ect
did the efi connection 24x swap with ls1 coils and 12200411 pcm with a stock calibration file from a 02 camaro ls1 auto trans, rewired by me and im looking for anyone who has a base tune for this to make sure everything is ok and it runs properly for a dyno trip and tune i already did the injector to bank reassignment for close loop fueling and set the injector flow rate as a constant instead of a slope but i just copied the value of 24.8 from a tune i found in the repository, it runs better now that i made those changes, but i still have misfire counts in scan tool data (Modis), and it ran ok before the pcm swap and opti removale
