First off, I am running an 0411 PCM with a 2003 Corvette Coupe base tune to control a super mild 406 sbc and 4L60e transmission.
406 SBC with the following mods:
Patriot Performance Freedom series 190cc heads, 64cc chambers
Holley EFI single plane manifold
Holley 36lb/hr injectors
Edelbrock ultra low profile intake elbow
GM DBW 78mm throttle body from 2000 Tahoe
GM 85mm MAF with screen from 2000 Tahoe
8 individual ignition coils from 2000 Tahoe
Custom grind camshaft: 196/216 @.050" .414"/.470" 116LSA-4.5*
Obviously I am using EFI Connection's 24X conversion package. My PCM was originally from a 2002 V6 Silverado, did a write entire with 2003 Corvette Coupe tune file. So, computer wise, we can just call this an '03 Vette coupe with the MAF failed for VE tuning.
FWIW I have successfully done a CASE relearn with it.
Currently I am trying to optimize part throttle timing, particularly in light load cruise areas.
For some reason I have hit a ceiling at 46* advance. I'd like to reach 50* in these light load areas.
That might seem excessive, but remember this is an old sbc with old slow burning chamber designs.
Am I missing some simple little thing that I'm going to look dumb for? Is there an internal limit in the PCM or a limit in the scanner?
I have searched high and low only to find nothing about this situation.
If anyone can give some advice or point me in the right direction, I'd really appreciate it.
I'll post my tune so someone can hopefully find something I have missed.
Thanks in advance! (pun intended)
Custom Cam 406 MAF.hpt
