Results 21 to 40 of 48
Thread: Fuel economy scaler
  1. #21
    Jun 2008
    Charleston, SC
    969
    Intresting... trying to find the density of e85,
    Depending on seasonal blend variations E85 will weigh approximately 6.5 pounds per U.S. Gallon, having a liquid density of approximately 0.77 - 0.79 compared to gasoline which has typical values of 6.0 - 6.5 pounds per U.S. gallon and a density of 0.72 - 0.78.
  2. #22
    Quote Originally Posted by Chris@HPTuners View Post
    mg/L
    The ECM uses this number to convert the mass of fuel delivered by the injectors to a L/hr figure
    Out of curiosity, as I don't speak or count sheep in hex, how do you ascertain that kind of fidelity from the code itself? Ive looked at some Porsche code and it was all a guessing game without some sort of "map". Delete if that's too far off topic.
  3. #23
    Tuner 07MontRedcp's Avatar
    Jan 2007
    Arizona
    187
    Quote Originally Posted by carlrx7 View Post
    Good find Carl, now find the values for E10 and we are all set. lol
    BJK
    APS TT 630 rwhp/654 rwtq @ 9 psi
    '07 C6, TR6060 conversion w/Z06 ratios. DTE Stage 4 Quaife Diff w/brace (3.73). Z06 Brakes, mild turbo cam & dual springs (222/222, LSA 115, .581/.581), LS9R clutch, LG GT2 Coilovers, Autometer Cobalt Fuel gauage, Progressive Alky Controller, and e-Boost2 Controller. PFADT poly bushing for control arms and Sports sway bars. MGW shifter. 3" B&B Fusion. RSI Stage 1.5 fuel system. RX dual valve catch can.
  4. #24
    E85 is around 780,000 in the GM calibrations.
    as for the units, well the fuel mass is in grams and somehow needs to get to litres/hour, look at the code it divides the mass by the "mystery number" and gets litres.
    https://en.wikipedia.org/wiki/Gasoline gives me numbers like 0.71 - 0.77 kg/L, so the numbers are 1,000,000 x that so it must be mg/L
    Now i need to lie down...
    I count sheep in hex...
  5. #25
    Senior Tuner DSteck's Avatar
    Mar 2008
    St. Louis, MO
    4,859
    No, you need to edit the boost enrichment function to be a table that has MAP and RPM as axis labels. And make 2006 Corvette operating systems have adjustable axis labels for spark! Lol.
    http://www.dsxtuning.com
    Just say no to bull s***.
  6. #26
    Jun 2008
    Charleston, SC
    969
    yes!
  7. #27
    Senior Tuner mowton's Avatar
    Mar 2007
    Florida
    3,773
    If E85 is 780000 and gas is 730000 could you say 1) there is a 6.5% difference between E85 and gas 2) assume E85 flows approximately 25% more than gas 3) so by decrementing the 730000 value by 6.5%, this would adjust for a 25% IFR/AF scale factor....that would be just too easy.
    Ed M
    [email protected]
  8. #28
    May 2011
    23
    I can't get this table to help me at all. I have my IFR cut in half and my Stoic AFR doubled. With the stock value my MPG is double cruising around town at 45 I see about 17mpg (shows as 34). I have messed with this table going 100,000 higher and lower and both do the same thing and make my MPG read 50+ on the driver info center. Don't understand how I can adjust the table higher and lower but It make the mpg read more, a lot more.
    Anyone else had a chance to mess with this?
    Daniel
    Pontiac G8 GT
  9. #29
    Tuner OldFartC6's Avatar
    Jan 2008
    North GA
    188
    Quote Originally Posted by mowton View Post
    Ed M
    I think you nailed it.
    I plugged in a value of 600000 to start with and my average dropped to about 17 mpg which is too low. Moved it back up to 680000. I guess I will just have to dial it in over time but I think your calculation may just do it.
    FYI, running 52 lb. injectors
  10. #30
    Jun 2008
    Charleston, SC
    969
    Does this effect any other calculations beside fuel mileage on DIC?
  11. #31
    Jan 2008
    North GA
    188
    I hope not. It didn't seem to effect anything else. The car drove and ran fine.
  12. #32
    not that i can see, the value calculated is sent out on the CAN bus so anything that receives that data and uses it will be affected.
  13. #33
    Jan 2008
    North GA
    188
    That's great and thanks! Excellent addition!
  14. #34
    Tuner midgetracr's Avatar
    May 2006
    NW Indiana
    153
    Yeah Chris added them for E38, E39 & E78, he's working on the E67's now(really weren't that many requested for them sorry Erik)
    Please add me to the list of those with an E67 that would like this feature.
  15. #35
    Oct 2009
    321
    is this in 2.24? im looking through a e38 tune right now and cant seem to find it.
  16. #36
    Jan 2007
    Arizona
    187
    Quote Originally Posted by doc350 View Post
    Look at post #14
    BJK
  17. #37
    Oct 2009
    321
    Quote Originally Posted by 07MontRedcp View Post
    Look at post #14
    BJK
    yeah i saw that. there is nothing that resembles that in two different e38 vette tunes i have. so my question was, is this in 2.24, or is there a 2.24 beta that i dont have yet?
  18. #38
    Jan 2007
    Arizona
    187
    2.24.74 is the latest version as of last night. It keeps being update with what ever is the latest stable version. The beta version (2.25 I think) is not available the way it was before.
    BJK
  19. #39
    Advanced Tuner Niemer's Avatar
    Jul 2012
    371
    I had doubled stoich and halved IFR with my new injectors, so I halved the values in this table and it seems to have brought my economy readout back in line. I'll report back after a few tanks.
  20. #40
    Jun 2011
    Montreal, Canada
    758
    Quote Originally Posted by Niemer View Post
    Have I gone nuts ? I started this thread and know it was there, but now that I have some time to play with this scaler, I cant find it in 2.24.52 !!!
    2007 Corvette C6 Vert. A6
    LME LS402, Pat G custom cam, ATI 10% OD Damper
    Circle D triple disc 2600, 3.42 Diff
    YSI, 3.0 pulley, ID 1000's
    Alky Control Meth,
    ARH 1 7/8 headers,
    1009 RWHP @ 7000, 817 RWT @ 6000
