Results 1 to 5 of 5
Thread: spark advance question
    is it ok to elevate spark advance table as long as no knock occurs?
    i have raised timing in cruising area by 9 degrees without a knock,, is that the right way to do it?
    09 CTS-V A6
    Nov 2009
    All Around
    3,149
    when it comes to timing where you want to reach MTBT especially in cruise areas it is best to be on a loaded dyno, yet with the E38/E67 PCM you can not adjust timing on the fly.
    Quote Originally Posted by SultanHassanMasTuning View Post
    MTBT?
    what would a loaded dyno give over street cruising?
    09 CTS-V A6
    Senior Tuner mowton's Avatar
    Mar 2007
    Florida
    3,773
    Maximum Brake Torgue... timing that provides the most efficiency and burn. The actual torque reported by the dyno will indicate that timing level.
    Ed M
    [email protected]
    Tuner 4evervette's Avatar
    Jan 2008
    dyno room
    169
    On loaded dyno you simulate a crusing condtion, with load , see how much tourqe ur getting for each rpm range , then increase ur timing to see if u gain much ,,,doing that you will find ur Min spark for best torque
    Not having knock does not mean for sure you gain any house power ....
    specialize in: V8 Conversion & Tuning (UAE- DUBAI)
    supercharge installation
    Salah clutches for Nissan, Toyota and GM car
